How to correctly build PrusaSlicer from source on linux
nicolas.n5
(@nicolas-n5)
Hi. I'm trying to build from source on linux, following the instructions, I get this:
-- SLIC3R_ASAN: OFF
-- SLIC3R_BUILD_SANDBOXES: OFF
-- SLIC3R_BUILD_TESTS: ON
-- SLIC3R_FHS: OFF
-- SLIC3R_GTK: 2
-- SLIC3R_GUI: ON
-- SLIC3R_MSVC_COMPILE_PARALLEL: ON
-- SLIC3R_MSVC_PDB: ON
-- SLIC3R_PCH: ON
-- SLIC3R_PERL_XS: OFF
-- SLIC3R_PROFILE: OFF
-- SLIC3R_STATIC: 1
-- SLIC3R_WX_STABLE: OFF
-- SLIC3R_STATIC: 1
-- CMAKE_PREFIX_PATH: (default)
CMake Warning at /usr/share/cmake-3.10/Modules/FindBoost.cmake:567 (message):
Imported targets and dependency information not available for Boost version
(all versions older than 1.33)
Call Stack (most recent call first):
/usr/share/cmake-3.10/Modules/FindBoost.cmake:907 (_Boost_COMPONENT_DEPENDENCIES)
/usr/share/cmake-3.10/Modules/FindBoost.cmake:1558 (_Boost_MISSING_DEPENDENCIES)
CMakeLists.txt:259 (find_package)
CMake Error at /usr/share/cmake-3.10/Modules/FindBoost.cmake:1947 (message):
Unable to find the requested Boost libraries.
Unable to find the Boost header files. Please set BOOST_ROOT to the root
directory containing Boost or BOOST_INCLUDEDIR to the directory containing
Boost's headers.
CMake Error at /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
Could NOT find TBB (missing: TBB_INCLUDE_DIRS TBB_LIBRARIES)
/usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
cmake/modules/FindTBB.cmake:274 (find_package_handle_standard_args)
CMakeLists.txt:311 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/x/PrusaSlicer/deps/CMakeFiles/CMakeOutput.log".
See also "/home/x/PrusaSlicer/deps/CMakeFiles/CMakeError.log".
How do I correctly reference the cmake dependencies file?
Also, how do i build with the exact same parameters devs use to get an Appimage exactly like the one built for stable releases?
Thanks
Respondido : 24/10/2019 5:10 pm
chmeredith
(@chmeredith)
RE: How to correctly build PrusaSlicer from source on linux
It looks like you don't have any of the build dependencies installed. What distro are you running?
Respondido : 25/10/2019 12:40 am
nicolas.n5
(@nicolas-n5)
@chmeredith
Thanks for your reply, i installed dependencies manually following slic3r wiki instructions, have not yet figured out how to install from the deps file, this is the issue i'm tracking: https://github.com/prusa3d/PrusaSlicer/issues/3099
Thanks
Respondido : 30/10/2019 11:21 pm
