How to change the layer height from a certain height in the print
sturzi
(@sturzi)
Hello
In order to print a (lengthy) rod with short threads on both ends (printed vertically) I would like to change the layer height twice during the print.
I would like to begin with 0.1 mm for the thread, then with 0.2 mm (or even 0.3 mm) for the cylindric part and then for the thread in the upper end again with 0.1 mm.
I'm using the Prusa Slicer 2.3.3. and cannot find the mentioned functionality. Maybe I have missed something or maybe there is a trick or a workaround.
B.t.w. I could save a lot of  time because the cylindric part of the rod is long and there are many rods to be printed.
Does anyone have an idea? Thanks!
Roebi
Opublikowany : 03/11/2021 2:46 pm
Ringarn67
(@ringarn67)
RE: How to change the layer height from a certain height in the print
@sturzi
"Height Range Modifiers"
https://help.prusa3d.com/en/article/modifiers_1767
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Opublikowany : 03/11/2021 2:53 pm
2 ludzie polubili
sturzi
(@sturzi)
That is exactly what I was looking for
Great! That is exactly what I was looking for. Thank you very much!
Roebi
Opublikowany : 03/11/2021 3:08 pm
1 ludzie polubili
Or you could use the variable layer height tool https://help.prusa3d.com/en/article/variable-layer-height-function_1750
Opublikowany : 03/11/2021 5:19 pm
1 ludzie polubili
sturzi
(@sturzi)
Full of surprises
Thank you! I didn't know that either. The Prusa Slicer is full of surprises.
Roebi
Opublikowany : 04/11/2021 8:25 am
