How to change infill extruder for painted parts
Robert
(@robert)
How can I change infill extruder on a painted wall? When the extruder for the wall is changed by multimaterial painting, the painted part is always using the same extruder for the infill. Default infill extruder is overridden by painting, infill extruder modifier does not work also. Is there a way to change the infill extruder for painted parts ?
Postato : 30/08/2024 9:36 am
BaconFase
(@baconfase)
RE: How to change infill extruder for painted parts
Not that I'm aware of.
Postato : 30/08/2024 9:44 pm
Snuffleupagus
(@snuffleupagus)
Utenti
@robert
I'll just express that this is possible, it's more then I'm prepared to convey on these forums, however you can do this by using two Parts occupying the same space with different properties applied.
I hope your able to glean what you need from this.
Good Luck
Postato : 31/08/2024 1:40 am
