How to add raft to print with footprint 200mm x 250mm (on i3 mk3)?
NR
 NR
(@nr)
I'm trying to print an object with a rectangular footprint of 200mm x 250mm.  This is right up against the 250mm limit of the print bed of the i3 mk3.  I can slice the object as long as I set the number of skirts to zero, but there are a number of internal holes and after some first-layer failures I think the print would do better with a raft.  But adding a raft adds support material that is outside the 200mm x 250mm footprint, with the result that "A toolpath outside the print area was detected."
I started flailing around with print settings, including setting "raft expansion" to 0, "first layer expansion" to 0, but these changes did not solve the problem.
Is it possible to include a raft whose footprint is no larger than the footprint of the print itself?  If so, what settings do I need?
Respondido : 31/01/2023 11:43 pm
What sort of failures?  Adding a raft will degrade the bottom surface quality.
Respondido : 01/02/2023 12:01 am
sungod3k
(@sungod3k)
RE: How to add raft to print with footprint 200mm x 250mm (on i3 mk3)?
just set the bed of the printer a bit bigger until the raft fits.
Respondido : 01/02/2023 3:55 pm
NR
 NR
(@nr)
Posted by: @sungod3k
How does this work? I'm already right up against the size of the print bed.  On the physical bed there's maybe 1mm of space on either side.  I don't want to be telling the machine to try to print the raft outside of its X travel...
Respondido : 01/02/2023 4:16 pm
