How do I reduce unnecessary travel for infill?
Pyro_Fox
(@pyro_fox)
I've been trying to move over to PrusaSlicer (from Simplify3d) for my home-brew printer but there are some oddities about the planner that still confuse me.
Settings:
  • Seam Position: Nearest
  • Infill: 100%
  • Infill fill pattern: Rectilinear
  • Bottom solid layers: 0
  • Bottom fill pattern: Monotonic
  • Top solid layers: 1
  • Top fill pattern: Monotonic
  • Avoid crossing perimeters: Enabled
  • Max detour length: 300%
Below is an example of how PrusaSlicer finishes the perimeter (1)  and chooses to pick the opposite corner to start infill (2)
Similarly, why does PrusaSlicer move back to a different object when changing layers? Is that something I can control? In S3D, I'm used to the next later starting from the object the last layer completed at.
Example where PrusaSlicer finished the last layer (1) and traveled to start the next layer (2)
Napsal : 17/06/2021 10:39 pm
1 lidem se líbí
RE: How do I reduce unnecessary travel for infill?
Pathing is very complex and subject to a number of settings that vary between slicers. We've had more than one instance where a user posted a "bug" about PrusaSlicer only to find out that they'd enabled Avoid crossing perimeters or similar features. Are you experiencing any actual problems or just curious?
Napsal : 18/06/2021 2:35 pm
1 lidem se líbí
Pyro_Fox
(@pyro_fox)
Posted by: @bobstro
This issue is dramatically hurting my print quality. Since I'm trying to print TPU, these random long travels give the filament time to ooze and create larger defects down the line.
Napsal : 18/06/2021 4:38 pm
towlerg
(@towlerg)
Just a guess but maybe set Max detour length to 0 to disable. Also play with seam position.
Napsal : 19/06/2021 12:31 pm
Swiss_Cheese
(@swiss_cheese)
@pyro_fox
Avoid crossing perimeters: Enabled, and Max detour length set to zer0, is a good start, and while there are many factors & Settings at play here, I'm going to skip the 50 questions and just explain how I've been handling this for the last 4 years. I print a great deal Of TPU and have had this issue many times.
What I do is place other objects on the print bed for example a small box or a small cylinder (scaled down you only want it to be a detour) and using trial and error I position these objects to steer or change the path of the print head or the printing order of the next layer to one more to my liking. depending on its relative position and height it will alter the path.
You can view the travel paths in slicer before committing to the print. this works, however it is more time consuming as it is a work around for the problem, As I mentioned I've been using this method for 4 years now and I have gotten pretty good at it, I would love to see prusa Implement weighted path hints markers or travel hints markers to slicer. but I have little to no faith in them that they would even understand it's need.
Hope this helps, good luck
Swiss_Cheese
The Filament Whisperer
Napsal : 20/06/2021 8:45 am
1 lidem se líbí
Pyro_Fox
(@pyro_fox)
That does sound pretty tedious indeed. Is there any advice on this issue?
Napsal : 15/07/2021 5:16 pm
PRNT MAN
(@prnt-man)
Saved the day - NinjaFlex with no stringing
Print settings > Layers and perimeters > Avoid crossing perimeters > Check
Avoid crossing perimeters - Max detour length = 0
Thank you guys and props to the programmer behind this.
Napsal : 05/11/2021 5:07 am
kesor
(@kesor)
This is more likely due to the seam location, when seam location is a "rear", the slicer will move all the way to the rear each time. Changing it to "nearest" will minimize travel moves for some models.
Napsal : 28/07/2024 7:57 pm
