How do I Change Orientation of Objects on the Bed?
kshaw
(@kshaw)
I want to print this file https://cdn.thingiverse.com/assets/65/f9/d9/7d/e8/top_corners.stl but have had problems getting one of the corners on all four objects to print correctly.  I would like to print these objects upside done from the original design to see if I can resolve the problems I have had.  I am able to use Prusa Slicer to reorient the objects upside down, but when I slice it and start print, it is back to the old orientation.  How do I flip these items so they will print properly?
Posted : 25/02/2022 6:47 pm
RE: How do I Change Orientation of Objects on the Bed?
I Looked at the file you supplied, and it looked Logically Upside down,  so I have turned it over for you,
I hope I have understood your requirements
top_corners upside down
Posted : 25/02/2022 7:23 pm
kshaw
(@kshaw)
Worked perfectly.  Thanks!
Posted : 28/02/2022 1:57 pm
