How can I force the perimeter to be a continuous line?
Franco Palombo
(@franco-palombo)
Membre
How can I force prusaslicer to make the perimeter a continuous line?
Project file: Camera_mount_LED_holder
Ce sujet a été modifié il y a 2 years par Franco Palombo
Publié : 08/08/2024 8:43 pm
Snuffleupagus
(@snuffleupagus)
RE: How can I force the perimeter to be a continuous line?
One way would be to switch to the Classic Perimeter Generator, change your extrusion width for external perimeters to 0.35, and you perimeters to 0.44 and Top solid fill 0.45.
Then turn off "Detect thin walls:" readjust your seams and set "Top fill pattern:" to Concentric.
I would also advise using support under the two detents at the base of the model.
At least that's how I would do it for one of my Prusa machines.
Good luck, I hope this helps.
Publié : 09/08/2024 3:20 am
1 personnes ont aimé
