Honeycomb rotated by 90°
drul
 drul
(@drul)
If I choose honeycomb infill the honeycomb is made as in the picture. To have a torsion stiff wing I would have to rotated the honeycomb by 90°.
Is such a rotation of the infill possible to achieve an infill like in a composite airwing?
thanks
Posted : 11/09/2023 8:28 pm
John
 John
(@john-6)
Consider cubic which I believe will add strength in the zaxis  direction. Caveat is I haven’t tested it.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Posted : 11/09/2023 9:19 pm
John
 John
(@john-6)
RE: Honeycomb rotated by 90°
Also gyroid will print a fill more suited to z-axis strength
Posted : 11/09/2023 9:24 pm
To answer your original question, yes, it is possible to manually set the infill angle. I’m not at my computer at the moment so can’t point you at the specific setting but PS has a built in search function you can use to find it.
Posted : 11/09/2023 9:27 pm
Print Settings→Infill→Advanced→Fill Angle. You have to be in Advanced or Expert mode to see it.
Posted : 11/09/2023 9:53 pm
...but 3D Honeycomb might suit you better.
Posted : 11/09/2023 11:28 pm
John
 John
(@john-6)
I got the impression the Op wants to orient the honeycomb sideways - but I could be wrong and yes a 3d honeycomb is a good option
Posted : 11/09/2023 11:55 pm
drul
 drul
(@drul)
Sorry my wording, yes the question was about orienting sideways. The Fill Angle Parameter only changes the angle around the Z-axes. Actually Rectilinear would be my favored infill to have max. torsion stiffness in the wing.
I think that could be a nice feature request?
Posted : 12/09/2023 6:02 am
drul
 drul
(@drul)
Or is there a feature like in this video with cura (see at 16:30):
With this feature I could add not just sideways rectilinear infill but also an aligned rectilinear infill for the Carbon-wingbar.
Posted : 12/09/2023 6:07 am
Cubic and 3D honeycomb are the infills to use for stiffness Imo and gyroid for resilience.
Posted : 12/09/2023 11:19 am
John
 John
(@john-6)
good to know
Posted by: @diem
Posted : 12/09/2023 10:09 pm
