Home After Extruder and Bed Reach Temp
SSIRon
(@ssiron)
I am looking at the gcode the slicer produces and it homes all axis after bed temp is reached then sets the extruder temp.  i would like to home after every thing is at temp.  Is there a way to change this order?
Napsal : 12/03/2023 10:40 pm
RE: Home After Extruder and Bed Reach Temp
Just edit the start gcode order in your printers profile and then save it (if its a default profile then you will have to use a new name).
Napsal : 12/03/2023 11:38 pm
which printer?
as far as I am aware, the Mini has a two stage warmup, which warms the hot end to about 170C, completes mesh bed levelling, and then finally heats the extruder, this is to address filament dribbling from the extruder.
the Mk2, Mk3, Mk3S and Mk3S+ on the other hand heat up fully and then do mesh bed levelling.
If you have this issue with a Mini,
Napsal : 12/03/2023 11:46 pm
SSIRon
(@ssiron)
this a railcore ii machine.  i will try this
Napsal : 13/03/2023 12:35 am
Good Luck
Napsal : 13/03/2023 8:27 am
