Hollow .stl generated as .gcode with a blocking layer
kenneth.b9
(@kenneth-b9)
I’ve got an apparent problem with PrusaSlicer.  Starting with an .stl file that
is intended/designed to be a hollow curved tube, and looks hollow both with F5
and F6 rendering in OpenSCAD, PrusaSlicer generates .gcode that contains
a level layer blocking the tube (i.e. it is no longer hollow).
Background:
OS X
Using OpenSCAD 2019.05
          PrusaSlicer-2.2.0+
When I import the .stl into PrusaSlicer, it initially looks hollow.
But after slicing, one end of the tube (the end with the wider
diameter) is blocked with a solid layer.  The blockage is apparent
in the visual rendering of the .gcode, and when I actually try to print
it out.
The .stl file can be seen here:
The .gcode can be seen here:
In PrusaSlicer, using File > Repair STL file…
does not seem to help (unless I’m somehow misunderstanding how to use it).
What’s my next step?
Thanks,
Ken
Opublikowany : 17/07/2020 9:09 pm
RE: Hollow .stl generated as .gcode with a blocking layer
Hi Ken,
you seem to have attached  links for two copies of the Gcode and No STL...
Joan
Opublikowany : 17/07/2020 11:10 pm
Posted by: @kenneth-b9
Background:
OS X
          PrusaSlicer-2.2.0+
it out.
Thanks,
Ken
Try to repair yout STL file with one of these tools:
https://all3dp.com/1/stl-repair-stl-file-online-checker-fix-3d-model/
I'm working with netfabb (Autodesk account required).
Opublikowany : 17/07/2020 11:34 pm
jsw
 jsw
(@jsw)
Meshlab is also a good .STL file repair tool.  Kind of a Swiss Army Knife of corrections.
Opublikowany : 18/07/2020 12:41 am
kenneth.b9
(@kenneth-b9)
Sorry.   I gave two pointers to the .gcode file.  The .stl file can be seen at
https://www.dropbox.com/s/7gymekmcv4dan1s/sopsaxbow.stl?dl=0
Ken
Opublikowany : 18/07/2020 1:17 am
@jsw
I totally agree, but it won't run on my laptop with an internal graphics card (Intel HD 3000); tested with version 2020.07. netfabb has the advantage that it can be used online.
Opublikowany : 18/07/2020 1:35 am
kenneth.b9
(@kenneth-b9)
Hah!  I had assumed naively that the .stl was OK, and that the problem was with the generation of .gcode.
However, the online Netfabb fixed the .stl file, and now everything looks great.  Can't wait to print it.
Many thanks to all who responded!
Ken
Opublikowany : 18/07/2020 2:38 am
