Hole in Surface
markus.dangl
(@markus-dangl)
Hole in Surface
I'm having a strange problem with PrusaSlicer 2.2.0
When I slice the model with PrusaSlicer, I see a hole in the model. However, this hole is not there when I use Cura.
Can someone explain to me why that is?
PrusaSlicer:
PrusaSlicer
Cura:
Cura
Este debate ha sido modificado el hace 6 years 2 veces por markus.dangl
Respondido : 13/08/2020 3:33 pm
RE: Hole in Surface
Could be a faulty stl. Try fixing with netfabb
Respondido : 13/08/2020 4:17 pm
markus.dangl
(@markus-dangl)
RE: Hole in Surface
@joantabb
i repaired it several times in prusa with netfab. the same problem over and over again.
I have already opened the STL in Meshmixer. You don't see a mistake there. In Meshmixer the contour is neatly closed.
I tried to upload pictures here in the forum. but somehow I don't succeed. can someone help me?
Esta publicación ha sido modificada el hace 6 years por markus.dangl
Respondido : 13/08/2020 4:32 pm
