Help for Gcode between object
Jordao
(@jordao)
Hello,
I try to print sequential object (cube calibration with one perimiter) and i need change extrusion multiplier calibration (M221) between object.
Can you help me to construct my Gcode for change M221 between object ?
Thanks !
Postato : 14/05/2021 5:42 am
Utenti
RE: Help for Gcode between object
What are you trying to do?  I am not sure I understand.  An image might help.
Postato : 17/05/2021 11:15 am
Normally inserting gcode from within Prusa Slicer is done using the preview layer slider and using the little plus icon on the slider.  However that function is not available when sequential printing is selected.
As such the only option you have is to manually edit your output gcode file.  Save it from PS and then open with any text editor.  Something like Notepad++ is good.  If you turn on the option to label objects PS will insert a description for when it changes to the next object in the gcode.
This makes finding the changeover point in the gcode list easier.  You can then manually insert the extra gcode commands at that point, save and send to the printer as normal.
Postato : 17/05/2021 11:34 am
Ringarn67
(@ringarn67)
@jordao
This is a tryout, DO NOT USE IT, unless one of the druids on the forum confirm it is correct 😀
And if it´s not correct, what is wrong.
My idea is two extruder with two different filament profiles
Attachment removed
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Postato : 17/05/2021 3:05 pm
dualixas
(@dualixas)
If anyone still needs a solution for this, I just found a solution today and upload it to Github. As I couldn't find it anywhere else. You can follow this guide on: https://github.com/magicdroping/How-to-PrusaSlicer-Sequential-printing-with-different-profiles/issues/1
Postato : 05/10/2022 11:41 am
