Height range modifier - bridge speed hangs on second temperature change?
Letterman
(@letterman)
I'm trying to test different bridge print speeds in the same print, and thought I'd use a temperature tower for this purpose with a constant temperature.
I'm not using g-codes, instead I've inserted several height range modifiers, where I change the bridge print speeds (see below).
For some reason, the print hangs at the second bridge speed change. The hotend simply sits on top of the print, with a blob of PLA extruded at 51% print completion. Hotend and bed are still at temperature, but there is no further movement.
Any ideas?
Thank you for your advice.
Postato : 21/09/2021 6:24 am
jsw
 jsw
(@jsw)
If this were my issue, I would inspect the generated gcode at that 51% point where the printer appears to hang.
I would try to figure out if bad code is being generated by the slicer, or if the printer is failing to obey valid code.
Postato : 21/09/2021 6:28 am
