Get list of issues with an imported STL.
Tango
(@tango)
I haven't had this issue before, but today, I dragged and dropped an STL file into PS. Apparently there are issues, but they aren't displayed, as usual. I do have a warning icon showing me there are problems, but I can't find a way to see a list of them. (Clicking on the warning icon, or double clicking, do not help.) Here's what I get right after I import this STL file:
As you can see (in the full sized version, since the forum cuts off part of the image), I don't get a report of what the issue is. I don't see how to pull up a list of issues from the entry in the list box, either.
Respondido : 14/01/2023 9:11 pm
ARU
 ARU
(@aru)
RE: Get list of issues with an imported STL.
How about sharing the zipped 3mf file to the community?
Respondido : 14/01/2023 9:14 pm
Hover your mouse over the warning triangle.
Respondido : 14/01/2023 11:27 pm
Tango
(@tango)
Posted by: @aru
I'm so used to just sending the GCode directly to my printer now that I didn't even think about saving a file. Definitely goofed on that!
I went back into Blender and fixed it, then re-imported it. So next time I have that issue, and if @Neophyl's technique doesn't work, then I'll be sure to save the file.
Respondido : 15/01/2023 3:13 am
If you are using Blender then I do hope you have turned on the optional 3dprint tool add on ?  That can generate a list of problem areas with your geometry and it can even highlight them for you.  It's even possible to get it to fix them, sometimes lol.
Respondido : 15/01/2023 10:44 am
Tango
(@tango)
I loaded in another object that PS corrected. I did see a report of what was wrong (something like, "Fixed 2 non-manifold edges"), but hovering over any part of the item in the list didn't provide any information.
Posted by: @neophyl
I learned, with a lot of pain and frustration, how to do quite a bit of that on my own, over about a month. Then someone told me about it and I found with one click, I could check on all the things I was taking extra time to do on all my objects before exporting them. Still, as frustrating as it was learning how to do things like double-check normals, look for manifold issues, and so on, I'm glad I learned it all before I found the tool so I understand what's going on.
Right now I'm working on learning how to add threads to cylinders and I've been getting help on BlenderArtists.org - which is also a nice forum for help, just like this one - and I've found that for some situations that "Make Manifold" button is great. Other times - well, at least it helps sometimes.
Respondido : 15/01/2023 11:03 pm
secv
 secv
(@secv)
It's a bug. Reloading a fixed model in PS will still show the warning icon.
If your model has issues, there will a list of issues on the bottom right in the Info panel. It will say exactly the issue with the warning icon and what was auto-repaired.
Respondido : 20/01/2023 11:31 pm
towlerg
(@towlerg)
Nor sure what you mean. I just loaded a known errored STL and hovering worked as Neophyl posted.
Respondido : 21/01/2023 3:27 pm
secv
 secv
(@secv)
  • load error STL
  • fix errors in Blender
  • right click > reload from disk
  • error icon displays in model list, but no errors shown in Info box
It's happened to me several times.
Respondido : 21/01/2023 4:23 pm
Tango
(@tango)
Posted by: @secv
Maybe it's my settings or something. I have upgraded (now) to 2.5, but still had the same issue. As you can see in the photo I uploaded, there was nothing in the bottom right info panel addressing this issue. That screenshot was taken right after loading. I have also not had a detailed report of what was auto-repaired. (I'm using Advanced mode.) So, yes, I think there's a bug, but on the day I had this issue, it showed up in 2.4.x, I deleted the STL import and re-imported. Got the same thing. Took the screenshot I posted and wrote a post. In the process of writing the post, I saw a post saying 2.5 was out. I installed 2.5 and got the same thing. (And, looking back, my memory may be off. I may have waited until I tried this in 2.5 to take that screenshot.)
Respondido : 21/01/2023 7:21 pm
towlerg
(@towlerg)
@secv Sorry I thought you were saying you had a problem wirg Prusaslicer.
BTW Ideamaker slicer seem to note and fix STL errors in a sensible fashion.
Respondido : 21/01/2023 7:58 pm
