Generating gcode from CLI for multiple printheads
prusaLover25
(@prusalover25)
I have multiple stl files (1.stl, 2.stl, ...), and I want to print each one with a different extruder ONLY using the command line.
I found that when I open these models in the GUI app and after selecting extruders and saving it as a project, I can slice the saved .3mf file from CLI. Also, I found that extruders are specified in the metadata.
<metadata type="slic3r.extruder">3</metadata>
But when I manually add this meta data to another 3mf file, it does not slice with the specified extruder, but opens it and shows the correct extruder in the GUI.
My initial plan was to merge and convert the STL files to AMF or 3MF like;
.\prusa-slicer-console.exe --export-3mf --merge 1.stl 2.stl
and then inject the metadata and slice;
.\prusa-slicer-console.exe -g --align-xy 65,45 --datadir [Path] -o [Path] --load [Path] [Path]\1.3mf
But as I said, it doesn't slice with the specified extruder.
I would love to get your opinions on the matter
Napsal : 08/11/2021 11:32 am
