Gcode not working on Genius
Kenny_ch2
(@kenny_ch2)
Hi
When i run my Genius with the gcode from PrusaSlicer, after the move to the skirt position, the printer stops.
I have to pause the print and resume and then it starts to print.
Can someone help me?
Thanks
Lichtschalter_V01
Best Answer by bobstro:
Sounds like your gcode isn't working properly. I've got a set of PrusaSlicer printer presets for the Artillery Sidewinder X1 here that should get you started. Just adjust for the smaller build volume of the Genius. Notes on importing presets here.
Edit: Your gcode indicates you are using some sort of automatic mesh bed leveling (ABL). What do you have installed? My presets are for NO ABL.
Respondido : 20/05/2021 4:27 pm
RE: Gcode not working on Genius
Respondido : 20/05/2021 6:13 pm
1 les gusta
Kenny_ch2
(@kenny_ch2)
Thanks a lot for your fast relpy.
Im a noob in 3D printing, got my first printer 2 days ago.
I used de default Genius profile from the PrusaSlicer without ABL.
Ill test your printer presets and let you know how it works, thnaks a lot.
Respondido : 20/05/2021 7:41 pm
Kenny_ch2
(@kenny_ch2)
It worked with your profiles. 🙂
Thanks
Respondido : 21/05/2021 4:55 pm
