Gap fill in Prusa Slicer is intermittent.
This anomaly showed up today. The gap fill (white) is solid in some places and intermittent in others.
The original file was a Sketchup STL and I can't find any issues there. The line width is consistently 1.3mm. Any suggestions on how to fix this?
Opublikowany : 18/03/2022 5:15 pm
Topic starter
answered:
RE: Gap fill in Prusa Slicer is intermittent.
I just figured it out. I checked the setting Detect thin walls under Quality in Layers and Perimeters. The problem is solved.
Opublikowany : 18/03/2022 8:30 pm
Due to the triangulation that occurs when the body is exported to STL, the line thickness may not always be the same along the curvature.
Opublikowany : 18/03/2022 8:54 pm
