FLOW RATE ignored in 2.5.0 Alpha 2
audry
(@audry)
I try to calibrate my printer using calculated flow rate using a single cube 20x20x20
Slicer ignores flow rate, and always requires the same filament length regardless of setup
It also ignores the filament start GCODE where I put the M221 statement, however the GCODE is commented at the end of the file.
Is it a bug or do I use the software the wrong way?
Napsal : 29/07/2022 1:22 pm
Swiss_Cheese
(@swiss_cheese)
RE: FLOW RATE ignored in 2.5.0 Alpha 2
OK so try alpha 3 it's been out for  a week or so and report back.
Regards
Swiss_Cheese
The Filament Whisperer
Napsal : 29/07/2022 3:37 pm
audry
(@audry)
Thanks
Tried 2.5.0 Alpha 3
What works now:  Filament start GCODE is expanded
What is still broken: Slicer still ignores Flow Rate parameter
I will use GCODE until the parameter is working, no issue
Thanks for info
Napsal : 30/07/2022 6:13 am
