Fix for Prusa Slicer 2.7 Malformed command 'EXCLUDE_OBJECT_DEFINE Error
If you are receiving this error with the new 2.7 alpha and are using Klipper:
It is because there is a new setting in Prusa Slicer that needs to change for Klipper users.
Go to Print Settings>Output Options>Output File
Change the label option setting to "Firmware Specific"
Problem solved.
Postato : 04/11/2023 1:40 am
1 persone hanno apprezzato
RE: Fix for Prusa Slicer 2.7 Malformed command 'EXCLUDE_OBJECT_DEFINE Error
Mine was already set to "Firmware Specific" but I still get the error. I do realize this is a year old.
Postato : 23/07/2024 1:58 pm
