Fix for Prusa Slicer 2.7 Malformed command 'EXCLUDE_OBJECT_DEFINE Error
If you are receiving this error with the new 2.7 alpha and are using Klipper:
It is because there is a new setting in Prusa Slicer that needs to change for Klipper users.
Go to Print Settings>Output Options>Output File
Change the label option setting to "Firmware Specific"
Problem solved.
Posted : 04/11/2023 1:40 am
You liked
