Fit variation, probably quantization
rickwise
(@rickwise)
I'm doing a series of test prints to try to fit to a Lego 2x2 block.  The goal isn't important, though.
I did a print with 4 samples with 4 different inside dimensions, 12.5, 12.7, 12.9, and 13.1, and found that it's between 12.7 and 12.9.
So I printed 4 more samples with 4 dimensions, 12.75, 12.8, 12.85, and 12.9.  I was surprised to find that the 12.9 fit was different between the two groups of samples.
Finally, I printed a set of 4 12.8 dimension parts, and they had different fits.  The obvious conclusion is that it depends on the X, Y position.  I assume this is caused by the quantization that happens in slicing.
I did another test, and found that it seems to be associated with the relative position compared to the X, Y of the start of the print, not the absolute X, Y of the printer.
So (finally) my question.
If I want to print a plate of 3 objects that all have the same internal fit, do I need to set their positions to be a multiple of the extrusion fit (I'm using the default 0.45mm)?  Is there some other way to make the objects consistent?
Napsal : 08/09/2022 5:52 pm
The new slicer has features designed to address this sort of issue.  It would be worth trying it before making any specific changes.
Napsal : 08/09/2022 6:36 pm
rickwise
(@rickwise)
RE: Fit variation, probably quantization
Posted by: @diem
I'll that, thanks!
Napsal : 08/09/2022 6:40 pm
rickwise
(@rickwise)
I upgraded to 2.5.0, it still behaves the same.  When I print a series of objects with inside width of 12.95 in the STL, what gets printed varies from 12.83 to 12.88 mm.
I can correct if it's a constant factor, but I don't know how to correct when the printed dimension varies by where it ends up on the print surface.
Napsal : 08/09/2022 8:01 pm
So the error is approximately a quarter of the default nozzle diameter and varies by one eighth.
If you are 'measuring' the stl by the design diameter be aware that almost all design software creates a cylinder by approximating a polygon with its vertices on the designed circumference and slicer will take this as a centreline position for the extrusion.
You are not going to get much closer.  Do these parts have to be snap-fitted repeatedly?  They are likely to wear in use...
I would be inclined to calibrate out about half of the absolute error and wear the parts to fit by repeatedly fitting and removing them from a typical lego block.
Napsal : 08/09/2022 11:50 pm
rickwise
(@rickwise)
Posted by: @diem
Thanks, Diem!  That will be my plan B.  I'm doing some experimenting to see if I can add a couple of minimal objects to force consistent location on the print plate, then ensure the objects are at multiples of the nozzle diameter.
Regards;
Rick
Napsal : 09/09/2022 2:21 pm
