First layer at 0.1mm and fix some small artefacts on the outer wall?
Alex_NL
(@alex_nl)
I noticed the default for the slicer is printing the first layer at 0.2mm.. is there a reason I should not use 0.1mm? I am printing a case for led lights and to achieve the best light diffusion i want to see if 4x 0.1 mm will give me a better result then 2 x 0.1mm and 1 x 0.20 (default). But usually defaults are there for a reason..
Another question is about the outer walls of the square boxes. While on the STL they appear to be perfectly straight when I print it the outer walls show small indentations. Anyone have an idea how to fix this? I included the 3fm file.
(this print is just a small cutout from the original so please don't look at the design specifics).
Front plate with color change2.3mf
Opublikowany : 18/04/2023 3:21 am
Hello
(@hello)
RE: First layer at 0.1mm and fix some small artefacts on the outer wall?
this is the best i can get it to goforumprint3mf
Opublikowany : 18/04/2023 3:36 am
Alex_NL
(@alex_nl)
I downloaded the file but I see little difference. What slicer settings did you try to change?
Opublikowany : 18/04/2023 3:41 am
Hello
(@hello)
the reason prusa slicer default is for .20 mm is because the lower you go the more time of course you culd go lower if you want really fine detail i would go to .10 or .07 but i recomend .10 with the settings i put in 3mf above
Opublikowany : 18/04/2023 3:43 am
Hello
(@hello)
i didint change much to be honest they are just the settings i use and i get amazing prints with my settings all my settings are fine tuned for that kind of stuff
Opublikowany : 18/04/2023 3:44 am
Hello
(@hello)
what would help is pictures of the print itself then we can see incase it is a hardware fault
Opublikowany : 18/04/2023 4:02 am
