Feature request: control support extrusion speed separately
Sean Roach
(@sean-roach)
I just saved about 20 minutes off my current print by cranking the speed up to 300% during the first layer of the support material, (it's a mask, so lots of open volume underneath.)
I looked, but could not find, an option to turn up extrusion speed for just the support material.
Is there a reason that support material needs to be laid down with the same care as the actual model?
Opublikowany : 07/10/2021 11:12 pm
Print Settings > Speed > Speed for print moves >  Support material:
You need to be in Expert mode.
Opublikowany : 08/10/2021 2:42 am
Sean Roach
(@sean-roach)
RE: Feature request: control support extrusion speed separately
I do not know how I missed that. I LOOKED.
Well, the current print is about 4 hours in, and the savings would be about an hour, so not worth it this time.
Thank you.
Opublikowany : 08/10/2021 2:54 am
