Feature Request - Add Table to Print Settings Tab show user defined favorite fill patterns
Bob D.
(@bob-d)
I couldn't find anything on this topic so started a new thread.
I find I am often cycling through the print settings trying out different fill patterns and other settings to see if I can reduce print time.
When I look at the screen on the Print Settings tab over half the window is unused, blank space. Why not add a new window that uses this open space which contains a table with 3 saved user favorite selected filament preset/fill patterns plus a fourth column displaying the current settings and show the affect each of the four settings has on print time, filament use, etc.
The table should be dynamic so that it updates in real time as you make changes to settings and can instantly see the results of your changes compared to your favorites.
Postato : 14/04/2022 2:14 pm
RE: Feature Request - Add Table to Print Settings Tab show user defined favorite fill patterns
Hi Bob,
requests like this need to be made on the Prusa Slicer Git hub pages
Postato : 14/04/2022 8:01 pm
Bob D.
(@bob-d)
Done
Postato : 17/04/2022 10:22 am
