Extrusion Multiplier modifier
wojciech.m3
(@wojciech-m3)
Hello, is it possible to add "extrusion multilplier" modifier area to printed object?
Best Answer by JoanTabb:
Hi Wojciech<
If the area you want to change is at the top of the model,  say your model is 30mm tall and you want the last 10mm to be slightly bigger
you could add an
M221 S105
Command when the Z height exceeds 20mm to increase the flow rate from that point on
this will have the similar effect to increasing the Extrusion modifier
Publié : 12/04/2020 4:44 pm
RE: Extrusion Multiplier modifier
What are you hoping to achieve? it may help us come us with ideas
Publié : 12/04/2020 5:21 pm
wojciech.m3
(@wojciech-m3)
@joantabb
Hi Joan, i need to thicken the walls of a printed object by about 0.1 mm (i have only STL) to make it fit better with another part. I get good results with increased extrusion multiplier, problem is, that i don't want to apply this modification to entire object, only a part of it. So naturally, i've looked into modifier shapes, but i don't see extrusion multiplier as an available modifier parameter.
Regards,
Wojtek
Publié : 13/04/2020 8:27 am
Area51
(@area51)
Membre
I would recommend to learn and use a STL editor to make the changes. All3DP has a list of free versions and some guide to using them: 7 Free STL Editors: How to Edit & Repair STL Files
Publié : 13/04/2020 10:24 am
1 personnes ont aimé
wojciech.m3
(@wojciech-m3)
@area51
Hi, ok, that is probably the right way to do it. Still, i wonder why extrusion multiplier is not available for applying with modifier shapes in Prusa Slicer?
Publié : 13/04/2020 12:23 pm
Hi Wojciech<
you could add an
M221 S105
Publié : 13/04/2020 2:27 pm
