Extrusion error
Fisheye_3d
(@fisheye_3d)
Extrusion error
Can someone explain what this error is about? I keep getting Support_material_extrusion_width=0.19 mm is to low to be printable at a layer height 0.2 mm. The thing is the extrusion width is set to .6 for everything including support, Ive tried .65, 100%, 120% etc and nothing works. It only is happening on one of my printers with whatever settings i use.
Napsal : 13/11/2021 1:41 am
sirvancelot112
(@sirvancelot112)
RE: Extrusion error
Did you ever figure this out? I have the same issue. The support material lines are thick, I was hoping to make them thinner. I cannot due to this error.
Napsal : 14/02/2023 3:39 pm
RE: Extrusion error
Please post a zipped up prusa slicer project file that is giving you the error when sliced.  A project file saved from PS is a snapshot of all your settings.  It allows anyone loading it to slice identically to you.
You MUST zip it up though as the forum only accepts a very limited number of file types.  If you don't it will just silently not attach it.
Napsal : 14/02/2023 6:08 pm
