Extrusion error
Can someone explain what this error is about? I keep getting Support_material_extrusion_width=0.19 mm is to low to be printable at a layer height 0.2 mm. The thing is the extrusion width is set to .6 for everything including support, Ive tried .65, 100%, 120% etc and nothing works. It only is happening on one of my printers with whatever settings i use.
RE: Extrusion error
Did you ever figure this out? I have the same issue. The support material lines are thick, I was hoping to make them thinner. I cannot due to this error.
RE: Extrusion error
Please post a zipped up prusa slicer project file that is giving you the error when sliced. A project file saved from PS is a snapshot of all your settings. It allows anyone loading it to slice identically to you.
You MUST zip it up though as the forum only accepts a very limited number of file types. If you don't it will just silently not attach it.
