Disappearing object - won't slice - MMU2S
drsp123
(@drsp123)
Hi - hoping someone can save my sanity - I have a 2 object 3mf file that whenever I slice one of the 2 objects disappears.  The 3mf file is here with illustrations below. Right bottom side panel P Letter 3mf
The 3mf was developed in Fusion 360 and an identically produced one with an 'R' letter works just fine.  I can also slice just the 'P' letter on it's own with no issues, but for some reason when it's embedded in the square panel and I slice it, it disappears.  Driving me nuts - any help greatly appreciated!
Opublikowany : 05/02/2023 6:22 pm
RE: Disappearing object - won't slice - MMU2S
Select the whole, click on 'Split to objects' and then slice.
Opublikowany : 06/02/2023 7:47 am
drsp123
(@drsp123)
Thanks - I should have mentioned I have tried that - the result I get with that approach is this criss-cross which I am reasonable sure would result in a printing disaster...:
Opublikowany : 06/02/2023 5:37 pm
So it might, I didn't check.
Did you by any chance forget to subtract the letter part from the panel to make a void which you then fill with the second instance of the letter?
Opublikowany : 06/02/2023 5:59 pm
drsp123
(@drsp123)
Thanks - I didn't do that, an in retrospect it seems obvious that i should have.  I guess I'm still rather stumped as to why the splitting is required at all - I have used the same workflow to create MMU prints before that worked just fine (no splitting, or void creation required) - I'm curious as to why it didn't work on this file.  As a workaround the split and create void I am sure will work though, if a bit more fiddly.
Opublikowany : 06/02/2023 6:41 pm
drsp123
(@drsp123)
Pretty sure it's a bug in prusaslicer - have raised an issue on github. https://github.com/prusa3d/PrusaSlicer/issues/9639
Opublikowany : 06/02/2023 10:21 pm
