Disable export to SD button
Rob65
(@rob65)
I just recently switched from Simplify3D to PrusaSlicer - should have done that ages ago ... PrusaSlicer gives me much better results on my printers.
But I use either Octoprint or a Duet controller so I only use the "Send to printer" button after slicing.
Is there any way to remove the "Export to SD card" button? From time to time I accidentally hit that button and it's then trying to write to a development board that presents itself as a USB drive?
Regards,
Rob
Publié : 03/02/2021 9:21 am
RE: Disable export to SD button
Posted by: @rob65
Regards,
Rob
As far as I know, this is only possible if this function is deactivated in the source code of the PrusaSlicer. Just ask in the Prusachat. To do this, login with your Prusa account and select the eshop. After a few seconds the chat window should open in the lower right corner.
Publié : 03/02/2021 12:35 pm
Rob65
(@rob65)
Posted by: @karl-herbert
Thanks, but I don't want to compile the code myself. Main reason is that I then need to recompile each time an updates comes out.
I guess I'll just have to be more careful as to which button I hit.
Publié : 04/02/2021 3:14 pm
@rob65
I would post your suggestion on github: https://github.com/prusa3d/PrusaSlicer/issues
Publié : 04/02/2021 4:02 pm
Rob65
(@rob65)
Thanks,
I just checked the issue list and found the "Send to Printer should be the default" issue ( https://github.com/prusa3d/PrusaSlicer/issues/3446)
Instead of creating a new issue with almost the same content I added my comment to this one.
I am a bit confused though: there are 1739 open issues and this issue was opened in January 2020.
I am a software developer myself and there is no way that any project has a good overview of the work to be done when there are so many open issues. Too me this looks like the issue list needs to be cleaned up.
Publié : 04/02/2021 4:19 pm
