Disable Append Settings In Gcode
E
 E
(@e)
Is there a setting to stop your print settings from being appended to every gcode?  I thought I saw this at one point, but maybe it was another slicer.
Opublikowany : 02/05/2022 12:25 pm
RE: Disable Append Settings In Gcode
I don't think so. The closest I have seen is Print Settings->Output options->Output file->Verbose G-code which reduces comments. In a quick test, it still appends the settings comment block at the end. If this is something you're concerned about, you could easily work up some post-processing scripts to strip comments. If you're worried about printer performance, it's worth noting that OctoPrint automatically strips comments before sending to the printer.
Opublikowany : 04/05/2022 1:55 pm
ellaa linn
(@ellaa-linn)
Remember to keep a backup of the original G-code file before making any modifications. Additionally, be cautious when modifying G-code, as incorrect changes can lead to unexpected or undesired behavior during the printing process.
minesweeper online
Opublikowany : 14/06/2023 7:18 am
