Delete preset printers in 2.9.4
ChiTownGuy
(@chitownguy)
I just upgraded from mk4s to core one and I would like to remove the mk4s presets from the slicer.
I tried running the configuration wizard and only selecting the core one printers but the mk4s printer presets are still there.  Edit/Delete Presets only lets you edit them not delete them.  I have tried everything I can think of.
How do I delete the presets in 2.9.4?
Napsal : 04/01/2026 4:02 am
1 lidem se líbí
Brian
(@brian-12)
RE: Delete preset printers in 2.9.4
I've had the same issue, I can't get rid of the non input shaping MK4 and XL as they are no longer listed as options.
Napsal : 04/01/2026 2:19 pm
brianjordan
(@brianjordan-2)
I have just uninstalled my MK3S from 2.9.4
Slicer -> Configuration -> Configuration Wizard -> Prusa Research...
Here you find a complete list of Prusa printers where I was able to uncheck the relevant printer and uninstall it.
Flashforge finder -> Flashforge Creator Pro -> Prusa MK3S -> Prusa MK4S ->???
Napsal : 04/01/2026 2:41 pm
1 lidem se líbí
Brian
(@brian-12)
Posted by: @brianjordan-2
My problem is that the Mk4 without input shaping is not there, same with the XL.  Hence the reason I cannot get rid of them.
This isn't just a 2.9.4 problem either, I haven't been able to delete them for over a year.
Napsal : 04/01/2026 3:45 pm
brianjordan
(@brianjordan-2)
Posted by: @brian-12
I have just been able to load and unload the pre Input Shaper profiles for both these printers. The location for both is a bit obscure in that you need to scroll down the list in the wizard beyond the MK2.5 and MK2 Families.  There you will find, under Legacy Profiles, the functionality you need - I think?
I realise I may have misunderstood your issue, in which case my apologies.
Napsal : 04/01/2026 5:15 pm
1 lidem se líbí
The OP also posted this in the similar thread  a few posts down in the forum, I replied earlier  (about 7h ago) to him and another poster asking the same question about the difficulty and mentioned the Legacy profiles and check that they were also deselected.  Guess I should have posted the information in both threads as it looks like the OP didn't check the replies there. https://forum.prusa3d.com/forum/postid/776570/
Napsal : 04/01/2026 5:29 pm
2 lidem se líbí
Brian
(@brian-12)
Thank you!
Napsal : 04/01/2026 5:31 pm
