Curved object not solid after slicing
I'm trying to print a small rail for a Gravitrax kids toy. After I slice it, the lower side rail of the curve is hollow. If you manipulate the angle of the object, you can see right through it. Before slicing it looks solid. How can I fix this?
Here is the stl file: Curve Rail.stl
Thanks for any tips you can provide
... Brad
Napsal : 15/03/2023 6:58 pm
RE: Curved object not solid after slicing
Hi Brad,
It appears that your part, has errors in the STL
If you are using Windows, you can 'Fix through the Netfabb'
Napsal : 16/03/2023 3:44 am
Topic starter
answered:
Wow - thanks Joan! That worked perfectly 😀
Napsal : 16/03/2023 2:04 pm
