[CR6-SE] PrusaSlicer - M117
Omexlu
(@omexlu)
Hello,
Does anyone use PrusaSlicer in combination with the CR-6SE and Community Firmware? Is there a way to show the remaining time (M117) on the display like Cura can?
Thanks in advance.
Publié : 11/10/2021 12:40 pm
Is support for remaining times enabled?
Posted by: @omexlu
Do you have Printer Settings->General->Firmware->Supports remaining times enabled?
Publié : 11/10/2021 2:01 pm
Omexlu
(@omexlu)
Reply
Yes but as I read it use M73 not M117? Don't know if it works with the CR6 SE that way.
Publié : 11/10/2021 2:11 pm
It does use M73.  The only instances I am aware of used a post processing scripts to parse and replace the M73 commands to the ones needed for your firmware.
You could also recompile your firmware to support the M73 commands.
Publié : 11/10/2021 2:25 pm
Posted by: @omexlu
Did you try it?
Publié : 11/10/2021 2:35 pm
