Cost & weight of print? Where did it go???
vintageb3
(@vintageb3)
Hi! I upgraded to 2,3,0 recently. Previously, after slicing, the weight and cost of the print was shown in the right hand window. Now I can only see how many meters of filament will be used even though I have entered the cost and weight of materials in the Filament Settings section. What have I done wrong?
Thanks!
Opublikowany : 16/02/2021 5:05 pm
RE: Cost & weight of print? Where did it go???
Iirc correctly you also need the density in the filament. I still get the cost on my 2.3.
Opublikowany : 16/02/2021 5:17 pm
1 ludzie polubili
vintageb3
(@vintageb3)
Hi Phil....Ah!....Yes! Currently set to 0. Will have to work out that parameter then.
Cheers once more!
m
Opublikowany : 16/02/2021 5:20 pm
Plastic density is almost certainly available via google but the other filament presets should also have suitable values.
Opublikowany : 16/02/2021 5:22 pm
vintageb3
(@vintageb3)
@neophyl
Thanks mate....I will check google!
m
Opublikowany : 16/02/2021 5:25 pm
vintageb3
(@vintageb3)
Sorted. Thanks Phil! 1.25g/cm3.....
Opublikowany : 16/02/2021 5:31 pm
That's confusing. I would prefer placeholder in a slicer, saying to fill in filament density instead of googling.
Values thought(density), I copied from Prusa's default profiles.
Opublikowany : 09/12/2023 8:52 pm
