Copying custom print, filament and printer settings toother PC?
[Solved] Copying custom print, filament and printer settings toother PC?
Pedja
(@pedja)
How can one copy custom settings to fresh PrusaSlicer installation on other computer?
Best Answer by Area51:
The location of all configuration settings can be found in the menu: Help -> Show Configuration Folder
The settings can be copied from here to a new installation on another computer.
Posted : 11/05/2020 12:04 pm
Area51
(@area51)
RE: Copying custom print, filament and printer settings toother PC?
Posted : 11/05/2020 10:46 pm
Theres a simpler much easier way than manually copying folders.  The slicer is designed to do this.  Go to file and export a Config Bundle.  That will save all the custom Print, filament and printer settings into an .ini file.  You can then use the ini file on another machine and using Import Config bundle restore all your profiles in one go.
Posted : 12/05/2020 6:10 am
Pedja
(@pedja)
@neophyl
Great, thanks!
Posted : 14/05/2020 10:27 am
tevashkevich
(@tevashkevich)
Posted by: @neophyl
This was exactly what I needed! Cheers
Posted : 15/11/2021 1:55 pm
