Complete individual objects arrangement boundary not showing in 2.9.2
theelous3
(@theelous3)
v2.9.2 - all good except the plater view no longer shows the additional clearance boundary around objects for arrangement when the complete individual objects output option is enabled.
This is very inconvenient.
For anyone unaware - previously with this option enabled, when you clicked to drag any object, all objects showed an additional clearance boundary which would block slicing if there was overlap as a precaution. The problem is this boundary is no longer being rendered, so it's guesswork when manually arranging objects.
Opublikowany : 22/06/2025 2:16 pm
Korvell
(@korvell)
RE: Complete individual objects arrangement boundary not showing in 2.9.2
Yes - same problem here ... no visible boundary. Please fix it!
Opublikowany : 09/08/2025 11:37 am
Gabriel Balogh
(@gabriel-balogh)
Yes - same problem in 2.9.3 Please fix it!
Opublikowany : 28/10/2025 10:56 am
This is a user to user forum.  Prusa do not monitor this forum for anything issue related.   All issues need to be raised at the prusa slicer github.  This one already has been raised.  https://github.com/prusa3d/PrusaSlicer/issues/14240
Go add your voice to it.
Opublikowany : 28/10/2025 1:15 pm
