change global prefernces - label objects
hawai
(@hawai)
Hi everybody,
does anybody know a sneaky way to turn the "label objects" parameter to "on" for every print settings profile at the same time?
According to my understanding I would have to go through all the print presets, turn it on and save the new presets. Or turn it on when I use that preset. Me being lazy and stupid, I would hate the boredom of the task and would certainly forget the one preset where I really wanted it.
The "label objects" parameter is used by the "cancel objects" plugin for octoprint and seems to be rather useful to have it on by default.
It is unfortunately not as simple as adding the line
label_objects = 1
to the common print presets section of the PrusaResearch.ini file.
Thanks in advance for the helpful comments.
Cheers
Hansjoerg
Posted : 01/06/2020 11:51 pm
RE: change global prefernces - label objects
Are you OK with of bit of hand editing a config .ini file?
Posted : 02/06/2020 2:24 am
hawai
(@hawai)
Sure, fine with me
Posted : 02/06/2020 3:42 am
