[Resuelto] Cannot set high speeds in PS
Jiří Fiala
(@jiri-fiala)
Hi, any idea why I can't get high speeds in PrusaSlicer? Even with something like a Voron, even when I set max speeds to like 200 mm/s everywhere, the actual sliced Gcode as well as the print itself never goes over like 35-60 mm/s. I want to tune Pressure Advance in Klipper and according to its docs, I should set 100mm/s speed - and I simply cannot do that. Same for input shaping.
Max print speed in the Expert mode is set to 300mm/s, Max volumetric speed is set to 0 (disabled).
Any ideas? Thanks!
Best Answer by Jiří Fiala:
It was the "Enable Auto Cooling" option in Filament settings. Rather hidden option for something so important...
Respondido : 28/11/2022 7:24 pm
RE: Cannot set high speeds in PS
Are both max volumetric set to zero ?  There’s a max volumetric limit in the filament profile too.
Respondido : 29/11/2022 6:08 am
Jiří Fiala
(@jiri-fiala)
Respondido : 29/11/2022 8:42 am
