Cannot add a new filament profil
rdeutsch
(@rdeutsch)
Hi
I have PrusaSlicer 2.7.1 installed and try to add new filament profiles into my printer setting. My printer is a MK3S+ with MMU2S.
I can add without any problems a new filament profil when i change to the printer "Original Prusa i3 MK3S & MK3S+ MMU2S Single" (that means the setting with only one filament works). But no way with a printer config using the MMU2S with the 5 filament spooler.
Any idea whats going wrong here?
Thanks for any support  & help.
btw: when switching the printer to "Original Prusa i3 MK3S & MK3S+ MMU2S Single" i can see my modified profiles (list of user presets). But not when switching then printer to "Original Prusa i3 MK3S & MK3S+ MMU2S"
Br, Robert
Napsal : 15/01/2024 6:27 pm
rdeutsch
(@rdeutsch)
RE: Cannot add a new filament profil
At the moment i think i found a solution for my problem. But i think it's not the standard way to do that.
When i open the filament-ini-file from my modified filament profil and change the ini-setting "compatible_printers_condition" to a copied value of a system preset then my profil will be displayed in the filament combobox. Now i can select my own filament from the list and can use it in my printer inherited from a "Original Prusa i3 MK3S & MK3S+ MMU2S"  (no Single!!!).
Napsal : 15/01/2024 6:56 pm
