Can you print directly from Prusa slicer?
peterpatchen
(@peterpatchen)
Can you print directly from Prusa slicer wirelessly?
Best Answer by peterpatchen:
Sorry Everyone, I just figured it out.
FYI for anyone with the same question:
1) In the Printer Settings Tab select the Cog at the top and Add Physical Printer
2) For the Neptune 4 Max, change Octoprint to Klipper
3) Enter the IP address of the printer
4) A Send G-Code button will appear in the Plater view next to the Export G-code button after you slice the model.
5) Click the button and select Upload or Upload and Print
This topic was modified 2 years ago by peterpatchen
Posted : 21/11/2023 3:07 pm
peterpatchen
(@peterpatchen)
RE: Can you print directly from Prusa slicer?
I would like to use the Prusa Slicer for my prusa and my Elegoo. I'm trying to print to an Elegoo Neptune 4 max
Posted : 21/11/2023 3:46 pm
Posted by: @peterpatchen
Yes, if you send data (gcode) to a print server (Octoprint or similar) which is connected to the printer (e.g. MK3) via USB.
wbr,
Karl
Posted : 21/11/2023 3:55 pm
peterpatchen
(@peterpatchen)
This post was modified 2 years ago 2 times by peterpatchen
Posted : 21/11/2023 4:02 pm
See https://help.prusa3d.com/article/sending-g-codes-to-printer-via-network-prusaconnect-prusalink-octoprint_196761
Posted : 21/11/2023 5:03 pm
