Can I remove the "MK3S" from the saved filename's template?
dclaar
(@dclaar)
When saving a file, the filename is always "bunch-o-numbers"_0.15mm_PLA_MK3S_13m.gcode.
The "bunch_o_numbers" is probably from Autodesk Fusion 360 invoking the slicer: I change them to a human-readable name.
But I only have a MK3S printer, so I don't really need that in the name, and removing it every time is a pain. (I remove it so that more of the information that I care about shows on the display). Is there any way to take that out of the template?
Best Answer by bobstro:
You have complete control over the generated file name. You can change it under Print Settings->Output options->Output file->Output filename format. The base filename is based on the STL name, but you can change it by right-clicking on the part listed in the panel on the right of the Plater view.
Publié : 23/11/2020 5:35 pm
RE: Can I remove the "MK3S" from the saved filename's template?
Publié : 23/11/2020 5:38 pm
dclaar
(@dclaar)
Thanks! The only bit missing from your answer is that one must be in "Expert" mode.
It doesn't show up in "Advanced" mode, so when I read your answer, I thought "Hey, I don't have that!" <confused face>
But knowing that it must be _somewhere_, I looked for some way to make it show up, and clicking "Expert" did it!
Publié : 23/11/2020 9:31 pm
dclaar
(@dclaar)
Ran into a bit of an issue though: Apparently, one must change it for every profile individually, and one cannot override system profiles, so I would end up with double the profiles. I guess I will just keep deleting. 🙁
Publié : 23/11/2020 9:53 pm
Membre
Changing the filename should not be an issue.
Publié : 23/11/2020 10:19 pm
dclaar
(@dclaar)
The "issue" is that I don't want to have 16 profiles. Although I guess if I did, it wouldn't ask me to turn on bridging detection all the time!
Publié : 24/11/2020 12:43 am
Membre
Does this help?
https://github.com/prusa3d/PrusaSlicer/wiki/Slic3r-placeholders-(a-copy-of-the-mauk.cc-page)
Publié : 24/11/2020 2:08 am
