can fuzzy skin be done on only select pieces in a multi part model?
salazar
(@salazar)
I have a multipart model. A sword.
Can fuzzy skin be added to select parts only, for example like the grip for example?
Or does it have to be cut and printed separately.
This topic was modified 2 years temu by salazar
Opublikowany : 09/03/2024 6:52 pm
Walter Layher
(@walter-layher)
You can add a modifier shape to your part and then do "Add Setting" > "Fuzzy Skin" on the modifier part. The fuzzy skin just appears in the areas where the modifier part and the original part overlap.
Opublikowany : 09/03/2024 7:00 pm
salazar
(@salazar)
Posted by: @walter-layher
thankyou.  I could not apply the modifier to only a specific part of the model . It at best had to be a cube volume area to modify. However I was able to do this on Orca Slicer with success
This post was modified 2 years temu by salazar
Opublikowany : 12/03/2024 2:07 pm
You can load a modifier - design any shape you fancy and load it as modifier or negative volume then scale and place to suit.
Opublikowany : 12/03/2024 3:55 pm
salazar
(@salazar)
RE: can fuzzy skin be done on only select pieces in a multi part model?
I will definitely need to try this out to carve out a sheath for my sword
Opublikowany : 12/03/2024 6:33 pm
