can fuzzy skin be done on only select pieces in a multi part model?
salazar
(@salazar)
I have a multipart model. A sword.
Can fuzzy skin be added to select parts only, for example like the grip for example?
Or does it have to be cut and printed separately.
This topic was modified před 9 months by salazar
Napsal : 09/03/2024 6:52 pm
Walter Layher
(@walter-layher)
You can add a modifier shape to your part and then do "Add Setting" > "Fuzzy Skin" on the modifier part. The fuzzy skin just appears in the areas where the modifier part and the original part overlap.
Napsal : 09/03/2024 7:00 pm
salazar
(@salazar)
Posted by: @walter-layher
thankyou.  I could not apply the modifier to only a specific part of the model . It at best had to be a cube volume area to modify. However I was able to do this on Orca Slicer with success
This post was modified před 9 months by salazar
Napsal : 12/03/2024 2:07 pm
You can load a modifier - design any shape you fancy and load it as modifier or negative volume then scale and place to suit.
Napsal : 12/03/2024 3:55 pm
salazar
(@salazar)
RE: can fuzzy skin be done on only select pieces in a multi part model?
I will definitely need to try this out to carve out a sheath for my sword
Napsal : 12/03/2024 6:33 pm
