Bug Prusaslicer 2.6.1. arringing instances on plater with sequential printing wrong
When I select sequential printing of 2 or more object, the auto arranging of the instances on the platter goes wrong and the instances keep overlapping..
I used this option in version 2.6.0 and the instances were placed correct on the plater without overlapping. Hope the developers can solve this issue in the next release (until then I have to manually position the instances on the plater).
RE: Bug Prusaslicer 2.6.1. arringing instances on plater with sequential printing wrong
With PrusaSlicer 2.7.0 this still isn't fixed...
If you think there’s a bug then you should report it on the Prusa slicer GitHub.
Please report such issues on github https://github.com/prusa3d/PrusaSlicer/issues
It is a bug, simply because it worked in versions prior to 2.6.1 😉
Done... but I was hoping they were also reading what was posted on this forum...
No the devs do not monitor the forums. Most of the Mods are also volunteers and don't work for Prusa. The only place to report things is github.
See I believe you have a problem but it works the same for me in all versions including 2.7 on my windows 10 machine.
I seem to vaguely recall something about it may not work properly until you actually right click on the arrange button and manually specify a distance but once you had then it started working. However that would have been a post on github Edit - think it was this one https://github.com/prusa3d/PrusaSlicer/issues/11258
... a simple right click on one of the objects on the plater "fixed" the problem and arranged the items the right way...
Still think it is a bug because on previous versions I didn't have to right click on one of the objects on the plater...
