Bug Prusaslicer 2.6.1. arringing instances on plater with sequential printing wrong
Mari
 Mari
(@mari)
When I select sequential printing of 2 or more object, the auto arranging of the instances on the platter goes wrong and the instances keep overlapping..
I used this option in version 2.6.0 and the instances were placed correct  on the plater without overlapping. Hope the developers can solve this issue in the next release (until then I have to manually position the instances on the plater).
Veröffentlicht : 23/09/2023 11:28 am
Mari
 Mari
(@mari)
RE: Bug Prusaslicer 2.6.1. arringing instances on plater with sequential printing wrong
With PrusaSlicer 2.7.0 this still isn't fixed...
Veröffentlicht : 02/12/2023 1:15 pm
If you think there’s a bug then you should report it on the Prusa slicer GitHub.
Veröffentlicht : 02/12/2023 2:54 pm
_KaszpiR_
(@_kaszpir_)
Please report such issues on github https://github.com/prusa3d/PrusaSlicer/issues
Veröffentlicht : 02/12/2023 3:28 pm
Mari
 Mari
(@mari)
Posted by: @neophyl
It is a bug, simply because it worked in versions prior to 2.6.1 😉
Veröffentlicht : 03/12/2023 7:15 pm
Mari
 Mari
(@mari)
Posted by: @_kaszpir_
Done...  but I was hoping they were also reading what was posted on this forum...
Veröffentlicht : 03/12/2023 7:16 pm
No the devs do not monitor the forums.  Most of the Mods are also volunteers and don't work for Prusa.  The only place to report things is github.
See I believe you have a problem but it works the same for me in all versions including 2.7 on my windows 10 machine.
I seem to vaguely recall something about it may not work properly until you actually right click on the arrange button and manually specify a distance but once you had then it started working.  However that would have been a post on github  Edit - think it was this one https://github.com/prusa3d/PrusaSlicer/issues/11258
Veröffentlicht : 03/12/2023 7:22 pm
Mari
 Mari
(@mari)
... a simple right click on one of the objects on the plater "fixed" the problem and arranged the items the right way...
Still think it is a bug because on previous versions I didn't have to right click on one of the objects on the plater...
Veröffentlicht : 16/02/2024 6:33 pm
