[Bug] Organic supports sizing/scaling between can be incorrect after version 2.6.0 alpha6. Support material would print on top of nothing.
Found the issue already reported on GitHub but wanted to post here as well to bring awareness if anyone else is running into this. Not hundred percent certain on what triggers the slice to be incorrect but seems to be on more complex organic structures that support multiple parts of a model and has large diameter changes over the print.
I was able to create a 3mf file with a box and some cylinders and painted supports to replicate the issue. Both beta 2 and rc2 have this issue from my testing. Changing the "Branch Diameter Angle" from default 5 to 2 will move the issue to another organic support in the scene.
Veröffentlicht : 20/06/2023 1:24 am
