Bug or change Post version 2.8.1
Jason Harding
(@jason-harding)
Good Day all
Prusa has supported our printers all along however we have just discovered an issue with support for our printers post version 2.8.1
One of our printers has a bed size X 1800. We have preconfigured profiles for our printers customers can download and use. Since version 2.8.1 we are getting an error on trying to use this profile.
There is a max bed size in the X axis of 1200, When trying to modify the size to the correct size I get the error displayed in the attached picture.
attempted to update X to 1800 however reverts to 1200 and shows error
The Snip of our profile that configures the bed size is below
[printer:Modix Big-180X Dual]
bed_custom_model =
bed_custom_texture =
bed_shape = 0x0,1800x0,1800x600,0x600
before_layer_gcode =
between_objects_gcode =
cooling_tube_length = 5
cooling_tube_retraction = 91.5
default_filament_profile = ""
default_print_profile =
deretract_speed = 0,0
end_gcode = M104 S0 T0 ; turn off extruder 1\nM104 S0 T1 ; turn off extruder 2\nG91 ;use relative coordinates\nG0 Z2.0; lift nozzle\nG90 ;use absolute mode\nG28 X Y;\nM84 ; disable motors
Opublikowany : 28/05/2025 6:14 pm
RE: Bug or change Post version 2.8.1
have you considered raising this matter on the Prusa Slicer Github, where the developers manage issues?
Opublikowany : 29/05/2025 8:02 am
Not sure how you ever got a bed size of 1800 as theres been an open issue about the max size being limited to 1200mm since 2021. https://github.com/prusa3d/PrusaSlicer/issues/6072
That predates 2.8.1.
Given that the multiple bed stuff came in right after 2.8.1 I'd say that they started using the 1200 limit in more places.
Opublikowany : 29/05/2025 4:00 pm
Jason Harding
(@jason-harding)
thank you for your replys, I was not sure if the best way was to post it here first before going to github but I will post it over there as well.
I would tend to agree with you @neophyl, we have always used the same profile and never had an issue with it functioning.
I would guess there is some check or balance that was added that is triggering the error.
I would guess most of our customers do use Prusa mostly for the idex side of things, I am more than a little shocked we have not come across this before.
Opublikowany : 29/05/2025 4:06 pm
