Brim painting
Nebulus
(@nebulus)
Brim painting
It would be great if brim could be 'painted, like for support or seams, I had a recent print where there was just a tiny part that would have needed brim to hold on the plate, it was just after 3hours print that it fell off, ruining the print. I hope it's not a duplicate, I didn't find any similar request in the forum
Cheers, keep on the great work on Prusaslicer 🙂
Veröffentlicht : 08/07/2022 10:25 am
Mitglied
RE: Brim painting
I would submit this as a suggestion on github.
https://github.com/prusa3d/PrusaSlicer
Veröffentlicht : 08/07/2022 11:02 am
Nebulus
(@nebulus)
RE: Brim painting
oh yep you're right 😮   I missed that
Veröffentlicht : 08/07/2022 11:10 am
RE: Brim painting
I see you already opened an issue, I was going to mention that before opening new ones you need to search to see if one already exists.  In this case it does https://github.com/prusa3d/PrusaSlicer/issues/8283   .  With over 2000 open issues and many more closed ones it is quite likely to already have been requested.
Veröffentlicht : 08/07/2022 11:20 am
RE: Brim painting
Not saying it's not a good idea but maybe just placing a part that area and making it one layer high might do (like Mickey Mouse ears on the corners of large objects to avoid warping).
Veröffentlicht : 08/07/2022 5:00 pm
Swiss_Cheese
(@swiss_cheese)
You can already put a brim anywhere you want, in any shape you want, on any object you want. This is not a belittlement of you or anyone else. you just need to educate yourself on the use of modifiers. This is still possible in 2.5 alpha as well.
Good Luck
Swiss_Cheese
Diese r Beitrag wurde geändert Vor 4 years von Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 09/07/2022 4:27 am
Nebulus
(@nebulus)
RE: Brim painting
Yep thanks for that advice, I think I have to revise my search techniques, didn't find it, should probably have insisted a bit there 🙄
Veröffentlicht : 09/07/2022 8:28 am
Nebulus
(@nebulus)
RE: Brim painting
The modifiers are indeed a good alternative, I think the Brim painting is still an interesting feature for future releases,and I probably wasn't thinking of this is because the parts were very small and I was too much focused on other possible failures; well, we'll see what future brings 🙂
Veröffentlicht : 09/07/2022 8:33 am
Henry
(@henry-2)
RE: Brim painting
Posted by: @swiss_cheese
Is there a way to specify that the added modifiers are to be classified as a brim though? While I haven't done it, my understanding is that the "brim separation" value can be tuned such that a brim provides good support to a part, but can be easily peeled off without leaving excess material and without a deburring tool. Do brims tuned in this way assist with holding down sharp corners?
Veröffentlicht : 09/07/2022 1:00 pm
Snuffleupagus
(@snuffleupagus)
Mitglied
RE: Brim painting
@zolmel
Maybe this will help you.
Regards
Veröffentlicht : 03/07/2024 10:07 pm
Amadeo
(@amadeo)
Mitglied
RE: Brim painting
Agreed that brim painting would be helpful.
The brim separation is a compelling reason to use brim and not a modifier.
The downside of modifiers is that they take longer to set up, and they overlap with the printed part.
Veröffentlicht : 17/04/2025 7:55 pm
RE: Brim painting
If you Merge a model with a modifier, they do not overlap.
Veröffentlicht : 17/04/2025 8:02 pm
Amadeo
(@amadeo)
Mitglied
RE: Brim painting
Thank you for sharing, I didn't know that this extra step would fix the overlap.
However, this illustrates the benefits of brim painting; using modifiers takes long time, necessitates a sequence of advanced steps, and the result doesn't honor the brim separation width. The steps are: create modifiers, scale them, ensure they drop to the bed and don't float in the air, then merge the model.
Veröffentlicht : 18/04/2025 8:56 pm
Snuffleupagus
(@snuffleupagus)
Mitglied
RE: Brim painting
It illustrates the benefits of education, the implementation of painting on brims is wholly unnecessary and impractical.
No, it doesn't, once again education is the key. Not only are they quick to setup, should you setup some that you like they are reusable in any project.
Not really, it's not for beginners, however it is not difficult at all. As well offers far more control as your knowledge of the software advances, as it should.
This is 100% incorrect.
Not only does it honor the "Brim separation gap" settings, it also honers "Brim width" and "Elephant foot compensation". It works perfectly, and across multiple Objects simultaneously if needed.
The steps you listed are incorrect.
This is a link to a post with the correct information, I hope this helps you.
https://forum.prusa3d.com/forum/prusaslicer/partial-brim-possible-not-around-the-entire-object/
Of course you have to be willing to learn.
Regards
Veröffentlicht : 19/04/2025 2:36 am
