Brim not working properly at x=900mm+
Fosstech
(@fosstech)
Using a Modix-120X printer that has a bed size of 1200*600mm, but when placing my print at x=900mm or more it no longer gets a proper brim. Is this a known problem?
Napsal : 01/11/2024 8:07 am
Quoc Trung Nguyen
(@quoc-trung-nguyen)
RE: Brim not working properly at x=900mm+
I am using BIG120X and have the same problem as you. However, for some objects that fully placed on the bed, you can use Skirt instead of Brim and set the distance from brim/object to zero
Napsal : 07/11/2024 4:35 am
