Bridging-Infill where no Infill should be
[Risolto] Bridging-Infill where no Infill should be
iceman83
(@iceman83)
IMG_0155 2
I have an STL from an Container that should be used as a Pen Holder. The Container have an open top.
When I slice with PrusaSlicer 2.4 the Slicer creates Bridging Infill an Massiv Infill and closes the Container...
I tried to block the Infill with a Modifier, I blocked Support, but nothing works.
I attached a video, that shows the Bridging Infill. Have somebody any idea to disable this?
Postato : 18/01/2022 7:25 am
iceman83
(@iceman83)
RE: Bridging-Infill where no Infill should be
I solved the problem by repairing the mesh in Fusion 360. Now there is no Infill...
It can be so simple, when you know the problem.... 🤫
Postato : 18/01/2022 7:34 am
Sorry cant download your movie at work as its blocked.
Please save your project from Prusa Slicer.  File>Save Project As.  This will save not only the model but all the settings you are using as well as any modifiers etc.  Its a snapshot of your slicing setup.  With it we should be able to duplicate the issue and figure out the problem much quicker.
However to attach a file to a forum post you must ZIP it up.  The forum is very picky about the allowed file types.
Postato : 18/01/2022 7:41 am
micha
(@micha)
Please try to right click that Model and fix through Netfabb. I suspect it has to do with open edges in the original model file. Did PrusaSlicer report such?
Does that change anything?
Postato : 18/01/2022 7:56 am
iceman83 hanno apprezzato
